Share part studios between different Documents.
Marco_Savary
Member Posts: 12 ✭
I'm not totally familiar with OnShape Workflow yet. Can I share part studios or parts between documents/assemblies? Ex: I want reuse a Hex head M10x50 between documents.
HTH
_Dave_
I'm looking to assemble a part that resides on "documents A" into "documents B". But as you answered it is not possible right now.
-A part released with a drawings inside of a document cannot be reused with another document. It must be remodel.
I can't see a work flow with 10 different products inside of a document, in order to reuse their parts.
Is it ever will be possible to share document between documents? All that external references and circular references! It looks daunting.
"Assembly tab" and "drawing tab" user cannot copy and paste in same and another document.
Also a fair bit of this . . .
For a single or small family of product, the documents container works very well, but in a larger family of products, I may have to rethink my project structure, because every single part must be inside of a single document in order to share and not to have duplicates.
Different! I will try that.
Now you may not have to rethink about your project structure.
You can refer below thread which will be helpful to you.
https://forum.onshape.com/discussion/3637/improvements-to-onshape-april-13th-2016#latest
