Replicating objects on Onshape
 irene_rivers
                    Member Posts: 17 ✭
irene_rivers
                    Member Posts: 17 ✭
                    Does anyone have any detailed, simple instructions as to how to to replicate a rook like the one of the link below:
https://s-media-cache-ak0.pinimg.com/736x/a6/98/03/a69803e6eb649618ee3a4fbcd5377e1a.jpg
Everything else is straightforward.
If I needed to replicate this (in/outside), I would probably model tile and use circular pattern, this would also produce more realistic data what is needed to build one (from bricks not 3dprint)..
Does anyone have any instructions for replicating the rook like the one of the link below:
http://images2.sw-cdn.net/model/picture/625x465_946298_5950160_1429679494.jpg
I already have the base and a cylinder on top, but I don't know how to make it "slanted", as well as the top part of the rook.
I'll probably be asking more questions in the future regarding chess pieces, so stay tuned!!!
Thank you to all who have helped so far
Then revolve like so.
Just another quick question: does anybody know how to do the upper part of the bishop?
http://images4.sw-cdn.net/model/picture/625x465_409222_8883560_1429671673.jpg
I have no problem building the foundation, but I've been having the same problem with my pawn, with the sphere on top.
I would suggest uploading the image you attached to your onshape document and then inserting it into a sketch.
1. Upload the file to your document. Start a sketch and select insert image.
2. The insert image dialog will pop up and you select the file name. This will allow you to sketch a rectangle of what you want.
3. Sketch the rectangle that bounds your image. I like symmetry so I tied the rectangle to be about the origin. I did this by selecting the origin first, then two opposite corners and chose mid-point. This forces the origin to be half-way between the two points. I then sketched a vertical line for my axis of revolution (and dimensioned it to get some idea of scale). From here I made a horizontal line on the bottom for a base then used a single spline to trace the outline of the bishop. Mine was a bit rushed and sloppy, but is editable.
4. Revolve the profile you created about the vertical line. This will create the majority of the bishop.
5. Because we revolved about a line tied to the origin, I decided to use one of the default planes to cut away at the top. I sketched on the front plane and made a construction line that was about the center then made perpendicular lines to make a region.
6. Extrude the profile in both directions through all and set the type to remove. This will cut away at the top.
The result is more or less a bishop.
Because this is something somewhat artistic, I mostly eye-balled everything. While no one has ever confused me with being an artist, it is a quick and easy way to trace something. If you are hoping for specific dimensions then you can go about and add dimensions. Likewise, if you don't want the thing to be just one spline you can break up the profile into lines, splines, and arcs.
https://s-media-cache-ak0.pinimg.com/236x/de/bc/57/debc579430e74bb9749f5922c29cee1c.jpg
There is no (very) quick way to do this, it will be some work until you get it right, or at least close enough. The devil is in the details on this one, the base shape is quick and easy as I described.
I realize that it will take some adjustments because you can't simply revolve half of the image.
How about the queen:
https://lh5.googleusercontent.com/-0cpp6rjruOU/UC4mwj4AINI/AAAAAAAAO3o/gKxk35SaNq4/s1600/332px-StauntonQueen2.jpg
I know that I'll have to revolve around the base, but would I have to trace the outline of only half of the picture; this is using the same technique that was mentioned earlier in this discussion.
I haven't tried this yet, but I'm planning on drawing half of the top of the knight, revolve it, and then glue both halves together to form the top part.
At the moment, I don't think I'll be printing the knight in one shot.
Any ideas on how to make that? I found someone else's files and I'm planning on printing that, but I'd like to try creating one myself.
ps. Is this project public? I would like to actually try online game in Onshape..
_Ðave_
I can't take the credit for the rook and knight because I used files from thingverse.
Everything else are my own pieces.
I'm not sure how to make the chess board, although I did find some cool files on thingverse.
Any ideas? A little help please.
Without any further thinking I would say draw a square, extrude to part and use pattern to create a board from many pieces, then use part color to make it chess board.
Can you please share a link to your project?
They're on different documents, but here you go:
Queen:
https://cad.onshape.com/documents/0adf021c00c0af91cf41d7bf/w/b1d6fb260600df0739499e9c/e/c8bd8f2abbc8e19ae5b1b06f
King:
https://cad.onshape.com/documents/d4a99597e047417d79fd52b7/w/ff97e7a0a6dc981e58eef218/e/60710b1b8dc79c4237c7a336
Pawn:
https://cad.onshape.com/documents/f304ac13336a4c7a8743e9e7/w/b1f7736084e249088fd14be2/e/219023eb501646ecbe1bfa29
Bishop:
https://cad.onshape.com/documents/d7bf74abf1cbdfe837f47313/w/0f49c2ab722ed8b63535ad95/e/5c8916d0eac1d261dcdda6cf
