Where is my imported model
When I first tried importing a step model, it shows properly with 2 tabs created: 1 as a list and 1 is the model tab. But somehow now after I import a model I only see the tab that lists the model file but the tab for real model is not shown, even though the translation went through okay, why?
NeilCooke Moderator, Onshape Employees Posts: 5,878
Hi Ray - if the second tab did not appear it means that Onshape was able to upload and store it in the Document, but there was a problem translating it. If you can share the STEP file with support, we can investigate why.Senior Director, Technical Services, EMEA5
