Equations in dimensions
arturs_ziprisarturs_zipris OS Professional Posts: 27 PRO
Hello, I saw that improvement request is completed, but can not find how to make equations in dimensiosn. Any help will be appriciated.
  • robert_morrisrobert_morris OS Professional, Developers Posts: 170 PRO
    edited February 2016
    To use an equation in a dimension, you still use the dimension tool but instead of entering in the value, enter in the equation that you want to use.
    Here is an example using a variable that was created earlier:
  • arturs_ziprisarturs_zipris OS Professional Posts: 27 PRO
    @robert_morris  Thanks so far, but I would like to see something like this https://www.onshape.com/cad-blog/whats-new-10-13-2015. Just did not find it before.
    @brucebartlett but why You do not like official video? I posted this quaestion only because could not find it. Suppose there is nothing better than official videos. :)
    @arturs_zipris, yes the video is good, just watched it, or part of it but I think though a picture may be a quicker to grasp the concepts.
    edited March 2016
    Good tip for creating a bunch of variables is to rollback whole feature list and use shift+enter when accepting > that will immediately continue with another new variable.
    Remember to think names twice, at the moment you can't change without rewriting all equations.
  • jeremie_bertinjeremie_bertin Member Posts: 1
    Shouldn't this be possible? Is there a workaround? I want to have 1 dimensions (width) as my "driving" dimension. If that value changes down the road, all the geometry will update based on the functions.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,232
    @jeremie_bertin
    Looks like you probably have a units error -- if you get rid of the parenthises (just #Width + 1/8 in) it should work.
