Equations in dimensions
arturs_zipris
OS Professional Posts: 27 PRO
Hello, I saw that improvement request is completed, but can not find how to make equations in dimensiosn. Any help will be appriciated.
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
To use a variable, insert with the icon at the end of the toolbar. These will then live in your model tree and can be dragged and ordered in the tree as required. I tend to drag all mine to the top of the tree.
You can the use #"variable name" to add it into your equation as @robert_morris did above with the #slot.
5
Here is an example using a variable that was created earlier:
Remember to think names twice, at the moment you can't change without rewriting all equations.
Looks like you probably have a units error -- if you get rid of the parenthises (just #Width + 1/8 in) it should work.
