Rotary cut
vic_blackallvic_blackall Member Posts: 1
On a plate, how can I do a rotary cut, for example a counter bored hole, through the plate and then copy around a set PCD.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,895
    If it's holes you're after, sketch a point where you want one hole to be, dimensioned from the centre (half the PCD), then use the hole tool, then create a circular pattern of the hole feature
  • cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 221
    @vic_blackall A counterbored hole can be created using the hole feature. If the hole feature isn't what you are looking for, than my next guess would be to check out the revolve command.
