New user, multiple parts need to be one
So I'm new to using on shape, i have in the past use other software but I'm just stumped, i have a part i have made, which was intended to be one part, but now i have 5 parts that need to be conjoined as one. some guidance would be helpful, do i need to add another app to do this?
1
There are some awesome training videos that will explain this functionality. Checkout videos on multipart design.
Add - Create material and add to the existing material
When adding material, you have the option to merge that material with other parts that touch or intersect its geometry:
Note that if the Boolean is set to Add, Remove, or Intersect and nothing is set in the merge scope, the feature will error. For New, no merge scope is available since New does not boolean the result.
Kindly refer below link video for more detail.https://cad.onshape.com/help/index.htm#extrude_video.htm?TocPath=Onshape%20Videos|_____5
