Make a Part of an Assembly
new_signup430new_signup430 Member Posts: 2
Hello
I am a new user of Onshape. I have downloaded a Assembly from GrabCad but there are no Mates that holds the parts together. Can a make a Part of the hole Assembly or make a "Fix" of the hole assembly...?
(I hva previously done this in Solidworks by saving the Assembly as an Part.....)
  • jakob_johanssonjakob_johansson OS Professional Posts: 3 PRO
    What I usually do is to mark all parts in the assembly and make a group. In this way the parts "mate" each other. Otherwise you should be able to export the assembly as a stp and then import it again.
  • new_signup430new_signup430 Member Posts: 2
    I have tried to make a Sub assembly (Group)of the parts but still the the parts did't mate..? I also tried to Export as an STP and import it again but it did't mate....  ??
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,971 image
    Box select everything, then right click "Fix"?
