Polygonal surface
Dega
Member Posts: 6 ✭
Sorry for the dumbest question ever, had a look in the forum without success.
How can I get a simple polygonal surface?
For ex. I sketch an hexagon and I want a closed polygonal surface with no thickness.
From here, click on Extrude. In the Extrude dialog, select the Surface option and select the edges of the hexagon:
After selecting them, adjust the extrude type and depth. You will have your hexagon as a surface:
I was hoping for a slightly different answer to this question. Sometimes I'd like to have a surface in a certain shape (like maybe the shape of a flat hexagon).
How can I turn that hexagon into a single flat surface (one that's listed as a surface on the left sidebar)
https://cad.onshape.com/documents/57487900676117b665eb1216/w/aab023256785150a9d8954d0/e/4fe478616ee226b05fe15f33
A planar surface feature would be nice.
Dries
www.keyshot.com
Dries
www.keyshot.com
https://cad.onshape.com/documents/a3ef2793d6f93b6b8c88d173/w/a25db7e050d47b3b4dea36fc/e/afe6505ebf43f7f4397b0b86
https://cad.onshape.com/documents/57487900676117b665eb1216/w/aab023256785150a9d8954d0/e/cc08441dd4695b6e099c5333
Dries
www.keyshot.com
Thanks for the answer but I was hoping for something simpler
https://cad.onshape.com/documents/52cc9108ce78e7f5e3a55619/w/cccd532887439925da9f8b9f/e/5468dd3d342230c3fbd2474a
I tried to loft the edges with the central point but the model disappeared.
Technically, this is not a hexagon, as it is not a single flat face. These are rather 6 triangles glued together at a very shallow angle.
Dries
www.keyshot.com
Create your polygon sketch, create two more sketches on the same plane, and "use" one side of your polygon in each, then loft between. Simples.
@Narayan_K understood, but I meant how can I draw the line using the edges as external reference?
edit.
I managed to do it, but is not a part and I cannot use it in assembly.
your solution seems pretty easy! I will give a try!
edit:
I managed to do the same, but I cannot get a part out of it and then I cannot use the file in an assembly. Is there a workaround?
https://cad.onshape.com/documents/1c8dd6954290ff5ef4ba383f/w/debdbd6dc7c15543b2583ac3/e/1287456660024ee7f47c9140
