sketch has to been between extents of extrude?
OpenR2
OS Professional Posts: 188 ✭✭✭
Is it a limitation that the sketch plane has to lie in between the extents of the extrude?
I have a single sketch that I want to reuse because its the same profile, but I want to have different start and stop planes.
I tried this with planes too.
Any time the sketch is not between the planes the extrude goes red.
Am I missing something obvious?
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 668
Rather than doing a remove, can you try it with a 'NEW' and see if the extrude succeeds? If it does, then there is some issue with your boolean condition.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com6
