fillets
gideonwaldner
Member Posts: 32 EDU
Narayan_K
Member Posts: 379 ✭✭✭
Onshape will not allow to make fillet between arc until there is a corner point.As a work around we can do like this,
5
can you make a fillet like the red shows
As it is now two arcs, the fillet between the line and arc can be made. First select the line to the right of the arc. Then select the arc above the line.
Linked[in]
