Has anyone else experienced missing files from STP assembly imports?
I have on two seperate occasions imported an assembly from Creo into OnShape as an STP file. On both occasions the resulting OnShape assembly was missing a component. The STP file opened correctly from within Creo so the component wasn't missing from the file.
shawn_pete Member Posts: 3 ✭
I tried uploading one of the offending files to individually to OnShape and received a translation failed message. I then submitted a ticket to support attaching the STP file. Turns out there was an error with a surface that was preventing OnShape from translating it. The support rep fixed the issue and sent me a healed STP file.
What I don't understand is why it happened in the first place. My desktop software was able to open the STP file (assembly and individual part) without issue. None of the other assembly components were affected.0
It will also allow you to share your document with Onshape support team as below.
You will get notification mail from Onshape immediately with ticket details and status.
Each part and surface should have a corresponding part studio, so would be interested to see if there are any surfaces in it. If not the best thing you can do for us to fix it is to share the document and step file with support (if you are willing).
