Make new part based on assembly?
simon_d
Member Posts: 6 ✭
I'd really appreciate some advice from more experienced users as to the best approach to this:
I'm creating separate truss parts in parts studio and then assembling them but I need to create a new part to join the truss sections together based on the assembly. Would it be better to actually build the whole model in a parts studio or is there a way of exporting the parts that I need to make a new joining piece to link between to a new parts studio retaining the same distance between them?
Are there standard corner joints like 90 degrees, 45 degrees etc?
see the marked icon on the attached picture,it is "dirived"
@coleman all the truss pieces are going to be connected in my model, at this point I suspect that they will all use standard joints.
Thanks for your input any further suggestions would be really appreciated.
I would go back to your parts studio and create two parts together. (you may be able to mirror or derive distance required to save you work time). Then create your adjoining piece in the parts studio. You can insert pieces seperately into the assy area so no need to start again from scratch.
I'm not clear on how to recreate the distance between these parts that I have arranged in an assembly in a parts studio so that I can create a new part to fit?
Many thanks
Simon
