Remove, leaves shell of lofted surface
Kind of confused here. Here is the link to the document
I have a lofted surface that I have thickened to form a slightly bent tube (finger splint actually)
and then because I want some flexibility, created a second lofted set of rectangles to form a tool to remove a slot on both sides. The slot object it then used to remove the slot.
However this doesn't work, as it removes the slot from the thickened middle but leaves the outer skin of the loft (the slot is way wider than the tube).
And whatever geometry it generates, the slicer hates it even worse... (if you turn 180 you get the opposite effect). And when you actually slice, it has a weird skin, and replicates the slot twice...
NeilCooke Moderator, Onshape Employees Posts: 5,891
Did you delete the surface using "delete face" like I suggested?Senior Director, Technical Services, EMEA5
