Helix Length
ryan_thiessen
Member Posts: 7 ✭
I was just wondering if there was a way to dimension or determine the length of a drawn helix in OnShape without having to use calculations?
I am specifically referring to this drawing:
https://cad.onshape.com/documents/56f19d3ce4b0673b5de81c73/w/45878ef17fa8d1624fd77cd6/e/c9f470239328414f8db0e6bb
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,436The only way to do this without calculations is to select the helix and look at the measured length bottom right. It is not possible to use this value dynamically in another calculation. Hope this helps.Senior Director, Technical Services, EMEAI5
What if you drew a 1mm long line in a sketch next to one of your helix's endpoints. Then you could use that line to create a surface sweep as the thing to sweep and the helix as the sweep path. Then you could use the MeasureValue FeatureScript to measure the area of the resulting surface. The area will be expressed as a mm*2, but the unit value just happens to be the length of the helix.
Sure, it's a hack, but one that gives you the length of your helix.
- Bob
Measure Value should allow the user to just measure the length of the helix directly.
I was wrong about this. See post below.
For reference @ryan_thiessen, this custom feature measures various values of objects and stores then in a variable for future use:
https://cad.onshape.com/documents/77baa8153589a7fc5f289829/w/cffd0f2a7077380d5378a885/e/d3174bf5315e6aafcb889367
To add a custom feature to your toolbar, just navigate to the document and hit that "+" button in the toolbar of that document.
It's been 3.5 years and I've moved on from this project and Onshape, but I appreciate you taking the time to respond. I think Neil's answer up top gave me the answer I needed, although I don't know why I never tagged it as answered.
Take care guys!
Sorry to bother @ryan_thiessen ! When I saw the new reply I thought the whole thing was a new post!
