Also, you are required to import additional parts into a part, and cannot choose them from your normal list of parts....lots of extra double work.
It's almost like in the design of this program they are needing to not mimic tools form other programs. But in the end, that is what we want, the tools that work and have been time tested, and not re-imagined tools.
Sure nice to see all the updates lately.
Surely you need to think hard to get mate right in first time but I rather think hard few times than click thousand times.
+ you don't need to mate stuff modeled in same part studio or even different part studios if modeled in correct position - just use default position and group
+ replicate tool is awesome for repeating mates
+ 1 mate connector = 3 traditional mates (in most cases) = just 1 feature to edit when adjusting position
Please do remember also that Onshape is not cloud version of solid works and some users might not have sw background so it's not always bad if they choose different path than sw. IMHO
- If you have modelled the parts in position in a part studio just drop them in and Group mate them together. No other mates required.
- If they are separate parts that don't align when dropping in , you could just use the Fasten mate between the 2 cylinders and then use the offset's to position parts, you find a quick quadrant spin down the bottom, however to change the angle more gradually you have to expand the mate on the tree to find the mate connectors, click 1, tick move and adjust angles around chosen axis's with the dialogue.
- If you want to go down the plane track as first mentioned you would need a Revolute or Slider mate on the two cylinders and then a Parallel mate (not planner mate) on the face's of the keyway cutouts.
Hope that help's,See this image for moving a mate connector in a fasten mate. as mentioned in point 2
