If two lines are coincident and covering each other, can I alternate between the two selections?
These two lines are coincident. One is shorter than the other, and completely covered by the other. Is it possible for me to select the shorter line?
Example: I want to mirror this equilateral triangle, but I'm unable to choose one of its sides, because that side is covered by a reference line. Here's a link to the sample document:
https://cad.onshape.com/documents/974b8eb1cb5e1180a1179851/w/268fbfe630effd058c7d6c8c/e/ebf1b7c0f14ca25d3cc02bbe
shashank_aarya Member Posts: 265 ✭✭✭
@chris_8 If you press right mouse button on the overlapped line you will get the option "Select other" which will give you the window for selection from two lines. From that you can select any line. See the below GIF animation.
5 -
chris_8 OS Professional Posts: 102 PRO
Thanks @shashank_aarya ! I tried the ALT, SHIFT, CNTRL keys, but never thought to try RMB.7
