Right-Click Problems with Firefox
When I right click inside the working window i get a Firefox related window as seen in the attached file. The OnShape context window is directly behind this one making it difficult to select. I have found if I hit "Select All" the Firefox related window disappears allowing me to use the OnShape window. I also found if I hit the Windows Snippet tool to capture this issue the Firefox menu disappeared. I am not sure if this is a OnShape or Firefox glitch. Is there a way to turn of the Firefox context help?
Windows 7 machine
Firefox 41.0.2
2
Windows 7 machine
Firefox 41.0.2
Switch Firefox contextmenu on/off so that Onshape contextmenu is visible …
Type in the Firefox command line: “about:config”.
Search for: “dom.event.contextmenu.enabled”.
Switch the value from “false” to “true”.
Now the Onshape contextmenu is visible after RMB click.
Or workaround in Onshape: ALT + RMB or RMB then ESC.
