Improvements to Onshape - January 27th, 2015
We recently updated Onshape with a number of refinements and some shiny new improvements. In this update we have streamlined assembly mating, improved manipulator tools and added features for collaboration, security and common workflows. Let us know what you think in the comments!
Highlights include:
Highlights include:
- Snap mating and an origin have been added to Assemblies as well as keyboard shortcuts for mate flip alignment (a) and axis rotation (q).
In addition to the origin in Assemblies, you can now use the manipulator to move selections to the origin, rotate 90/180 degrees about any axis or align/anti-align to Z on any manipulator direction. - Plane resizing handles (even on default planes)
- Transform manipulator
- Follow mode, collaborative viewing (double click on a user icon to see what they are doing. Editing rights required). Below are two users (left/right) taking turns following each other.
- Two-Factor Authentication (2FA) - Two-factor authentication adds another layer of security to your account. With two-factor authentication your phone provides a security code that you must provide to OnShape in addition to your password in order to sign in. Even if someone obtains your password they cannot sign in unless they also have access to your phone. Learn more about two-factor authentication at Onshape help.
- Export to SolidWorks (Translation) of Part Studios
- Share with Onshape support link
Linked[in]
LearnOnshape facebook group
That's just plain jaw dropping...
Dries
Nice new staff!
Ingo Knoch /Lino GmbH Germany.
Even the 'un-provements' like the middle mouse button changing away from rotate view and being pan now. And yes it bugs me enough to mention it as much a possible here on the forums. So you know I am about to become your proverbial squeaky wheel on this mouse issue....
Sneak peek, perhaps?
Dries
Dries
Unless there is some way I don't know about to pause gif animations, it would be good if they were recorded at maybe half the speed of those on this page. The time it saves by whizzing through at warp speed is more than offset by the number of iterations needed to work out exactly what is happening. (I don't AFAIK have the option of downclocking the OS temporarily, as I'm viewing on a Chromebook)
I would hate to see creation of these handed off to marketing in due course; it would be easy for the emphasis to fall increasingly on "impressing" the user, even to the detriment of "informing" them...
ON EDIT: the third point above, "Transform Manipulator", is too cryptic for me. A bit of explanatory text would have been very helpful, or at least a link to the appropriate help item, if it already covered the change...
