Poor Image Quality
duane_1duane_1 Member Posts: 17 ✭✭
Hello,
Have a new tablet, HP 10 G2, running Android 5.0.1. , and downloaded the Android Onshape app.
The images of parts  are poor.  The line and corners are not straight, jagged and box like.   Also part does not hold a 3d shape when rotating.  It will turn flat when spun between views, as show below.
Any suggestions to get this app to work better.
Thanks
Duane
  • rbaekrbaek Moderator, Onshape Employees, Developers Posts: 77 image
    duane_1 said:
    Hello,
    Thanks
    Duane
    Hi Duane,
    This appears to be a graphical issue that can occur in specific android devices. Do you know the exact model of your HP devices? That will help narrow down the issue. I strongly encourage you to submit a ticket via the Feedback option in the ? menu and our support team will work with you to address your issue.
  • duane_1duane_1 Member Posts: 17 ✭✭
    Thanks
    The product No. of the HP 10 G2 tablet is
    N3T44AA#ABA
  • qual_tunqual_tun Member Posts: 2
    Iam having the same problem on an android phone running 5.1 lollipop
  • don_howedon_howe Member Posts: 136 ✭✭✭
    I have a Samsung Galaxy tab S2. The image quality on my tablet is great. I haven't observed any issues with part manipulation and except for very large radii which is a known issue it runs perfectly.
    I believe the problem is with the mediaTek processor, anyone with a mediaTek proc NOT having these issues?
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    @duane_1 We are seeing this with the MALI 450 GPU.  We are seeing this across a number of devices and looking into it.
  • stuart_risbystuart_risby Member Posts: 2
    I have the same problem with an android tablet with a MediaTek processor. Do you think a solution will be available soon, or should I buy a different tablet? Thanks.
  • tom_borlaugtom_borlaug Member Posts: 1
    are you any closer to a fix for this problem? any updates? I have the same problem.
  • rob_thompsonrob_thompson Member Posts: 3
    Same problem on my Samsung Galaxy Note 10.1 , Android 4,4
    Thank you Onshape,
    I'm now able to use the App on my tablet with the new update.
    Duane
