Circular pattern bug
zaron_gibsonzaron_gibson Member Posts: 1
edited April 2016 in Community Support
So the top left find was made by me and then I circular patterned it around the shaft. As you can see. two of them refused to fully build.
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    @ zaron_gibson , Which type of pattern you used(feature/part/face)?
    If you used feature pattern then we have to check which end conditions you used for first blade.
    If possible please share the document and paste the URL here.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,861
    The most efficient way to pattern this particular shape would be to pattern the part using the intersect option.
