Documents
josiah_stahljosiah_stahl Member Posts: 1
I only have 1 document going right now in the "My Documents" section. Why does it say i have only 7 left? its also only 10 megabytes but it says I have 46mb filled already
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 image
    To decrease your amount of private data or number of private documents, you can do any of the following:
    1.  Copy workspaces to clear the Workspace history and delete the old document (don't forget to empty your trash). Select **Copy workspace** from the gear menu.
    2.  Make documents Public (the Onshape Free plan has unlimited Public documents within 5 GB of free storage). Select **Make public** from the gear menu.
    3.  Remove yourself from shared documents. Select **Remove from share** from the gear menu.
  • lanalana Onshape Employees Posts: 746 image
    @josiah_stahl
    Documents in Trash count toward your account - check if there is anything there.
