How to fillet the top of a cylinder
allen_stewart
Member Posts: 32 ✭
Hello All,
How do you give the top face of a cylinder a fillet?
Thank you
Thank you
- Select the FIllet tool
Fillet tool in toolbar
- With the Entities to fillet field active, select the edge or face of the part depending on your requirement.
- Change the fillet dimension as per your requirement. and press Enter to see the result.
- Click
to accept the feature.
Specific delete button is not available in Onshape. But you can delete any feature and entity by right clicking on that and delete option will appear. Also you can delete any entity or feature by selecting and press delete button from key board.Kindly refer below video for more detail.
