How do you create a dimension relationship in Sketch
Jerome_CastanedaJerome_Castaneda Member Posts: 1
edited May 2016 in Community Support
how do you create a relationship of dimension say L = 2*W where L = Length W =  Width parameters.
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373
    This is a great use for Onshape's variables: https://cad.onshape.com/help/Content/variable.htm
    Our variables are very powerful and I have multiple examples I can show you for various situations. I have a design where I have one variable, width, and use it to drive all  the other dimensions of my part so that if I need to make an adjustment, all I have to do is change the width variable.
    With good design intent variables are extremely useful.
    Twitter: @bradleysauln
    edited May 2016
    @Jerome_Castaneda, You can create relationship for dimension by using variable feature. Kindly refer below video which will be helpful in dimension creation by using variable.
