Imported Models
We work in industrial automation and would like to start using Onshape instead of SW. However, OS doesn't seem to handle importing parts that well. We have to import a lot of models that are provided by other manufacturers whose parts we integrate. In many cases these STEP files, for example, are imported with thousands of surfaces and/or parts. I would love it if there were a way for these to be simplify these into one solid since that is often all that is needed.
The other thing for this industry is that it is a bit cumbersome going back and forth between a part studio and an assembly. In many cases, we insert an air cylinder, for example, into an assembly and mate it as needed. We then need to transfer mounting holes to a frame we created. There is no way to do this in OS without going back and also inserting the cylinder into the part studio and doing it there.
This type of workflow for this sort of application seems a bit disjointed. Perhaps I'm going about things in the wrong manner. Any suggestions would be great.
1
On the STEP files that come in with surfaces, that is likely due to how they were exported by the program that originally made them. I would try to import them into SW and check them there. SW will usually let you know if there are problems with the part (bad edges, missing faces, etc.) and can sometimes fix them. If SW can fix them, then you could export them back out of SW and bring them into Onshape.
I was just curious if there is a known good method on how to approach the issue of imports with high numbers of 'surfaces'.
On most of the items I import I do not want to update any of the features, for example on this connector below.
Ideally (wish list) I would like to just work with this item as a single solid, but anything to simpl
Try our PCB Fixer custom feature:
https://cad.onshape.com/documents/9a9b81d17d4b69e58ad9b0b0/v/c253688ad8add5efd222a709/e/3152191074466a8b45231663
To add this feature to your toolbar, just follow that link and then click the '+ Custom features' button at the top of the page.
