Radial mate connectors
I can't figure out how to make a pie and then have the pieces of the pie expand out radially on mate connectors. My goal is to allow an exploded view of the object. Can this be done? I need a mate connector down the centerline of the piece but there is none. Can this work on a round shell (ie no tip of the pie piece to work with)?
traveler_hauptman Member, OS Professional, Mentor, Developers Posts: 419 PRO
@malay_kumar You are right. Good catch. I tried that and it did not work, but I was trying to select the origin in the feature tree instead of in the graphics window.
5
Working with non-part entities in Assemblies is not implemented yet. (You want to move your parts relative to some center point.)
You can hack around this by creating a small part to be at the center.
Once you have that, for each direction you want to explode you can attach a mate connector to the "center" and a mate connector to the exploding part, aligned in the direction you want. This will work even with no pie 'tip'.
So if you have 5 pie pieces, you will have 5 mate connectors attached to the "center" part, each rotated to face the direction you want, and 1 mate connector each for the pie pieces.
