Paste buffer is stuck, always pasting old sketch from several days ago
don3schdon3sch Member Posts: 9
I understand from another post that this problem must be fixed on the server side.  Can I please get the paste buffer reset fix applied to my account.  Manually duplicating sketches is getting old...  I waited a while to report this because I thought it was a glitch that would pass.  Thanks,
  • raj_Onshaperaj_Onshape Onshape Employees Posts: 111 image
    Is there a reason why you cannot use derived part functionality to insert just the sketch into another document ?
  • abefeldmanabefeldman Member Posts: 166 ✭✭✭
    @don3sch - have you tried clearing the browser cache by holding the SHIFT key and refreshing the page?
    Abe Feldman
    UX/PD/Community Support
  • don3schdon3sch Member Posts: 9
    I have used totally different computers in different locations, it is for sure on the server side.
    Ahhh, this doesn't get around the root of the problem that regardless of computer, browser, Onshape document, or function of operation.  A sketch from last week gets pasted into EVERYTHING I DO!
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 image
    @don3sch  This is a bug.  I will capture it..
