Is there undelete for tabs yet?
tom_jellytom_jelly Member Posts: 23 ✭✭
edited June 2016 in Community Support
I built an object in a parts studio tab 1 with a derived part from an adjacent tab 2, then did a boolean union of those objects.  Assuming I now had a single unified object I deleted the adjacent tab and the portion of my tab 1 object disappeared, I don't see a way to get it back or undo.  Any suggestions?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,233
    You can go to the versions-and-history and restore to a previous change.
  • jblcjblc Member Posts: 3
    The gear does not show up anymore on a History entry. How can I undelete a tab/document?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,861
    @jblc the UI was changed a few weeks ago.  Right-click to see the menu.
