Right-Click Problems with Firefox
alan_colealan_cole Member Posts: 1 EDU
When I right click inside the working window i get a Firefox related window as seen in the attached file.  The OnShape context window is directly behind this one making it difficult to select.  I have found if I hit "Select All" the Firefox related window disappears allowing me to use the OnShape window.  I also found if I hit the Windows Snippet tool to capture this issue the Firefox menu disappeared.  I am not sure if this is a OnShape or Firefox glitch.  Is there a way to turn of the Firefox context help?
Windows 7 machine
Firefox 41.0.22
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,012
    Can you try on the current build of Firefox?  45 I believe is the current build.  42 was released in November.
  • miguel_a_santiago_jrmiguel_a_santiago_jr Member Posts: 2
    I'm currently running into the same issue with onshape on Firefox. I'm using windows 10 and on the Firefox 47.0 build. Thanks!
  • HakroHakro Member Posts: 67 ✭✭✭
    edited June 2016
    Switch Firefox contextmenu on/off so that Onshape contextmenu is visible …
    Type in the Firefox command line:  “about:config”.
    Search for: “dom.event.contextmenu.enabled”.
    Switch the value from “false” to “true”.
    Now the Onshape contextmenu is visible after RMB click.
    Or workaround in Onshape: ALT + RMB or RMB then ESC.
    Hakro, Thank you very much for the tweak in firefox and the workaround!!
