How to incline a plane for eg a roof
baumar
OS Professional Posts: 83 PRO
Hi,
I'm trying to incline a plane for a roof. I tried to use draft, but it didn't work. I think I saw this in a video in one of the many steps, but I can't find it again.
For ease of description I created a small example under https://cad.onshape.com/documents/ebb05669046446eea2043a7b/w/6db80791788eda8622f33b5f/e/555ad30ddb93176925c61dd9
There is a pound in the middle (for demo purpose it is solid) and I would like to incline the plate to the right and the left so they would lay on the pound.
Thanks for help
Markus
Thanks for help
Markus
baumar
Hi Bruce, yes it does help, I can now rotate an element. What I could not manage properly is the following: if the part refers to a base plane, then I have to stretch the element. I have to fix a line and define a line or point to where it should be stretched. It's a bit difficult to describe, but I found an good example: create a pyramid from a base plane to a given peak point, as I sketched in Pyramid https://cad.onshape.com/documents/294778f0f2aa9b816d4bccca/w/a87bbbd68e49f2f904fb13c9/e/ad9abb1ee3b6ca4b82398cf7
To create the faces of the pyramid, the outer line has to remain constant, whereas the other to lines have to stretch.
I tried to add another transformation, like scale or distance, but that didn't stretch properly
Would you know an elegant way how to do that?
Thanks a lot for help and sorry to strain your patience, but maybe this help others too5
You can also use the transform rotate the part.
Hope that helps.
