Select the icon just past the middle
Select Translate by XYZ on the dialogue drop down.
You can even use the triad to move the components in the graphics area if desired.
my issue is when sketching a drawing,
I have multiple drawings that are identical shape wise but differ in width/height
when i copy paste the sketch and try increasing/decreasing in height/length in x,y directions on a single segment
all attached drawings off that vertex intersection either skew in size or only the line changes height but nothing else attached to it moves??
in cad i can change the segment length and the drawing shifts in the same direction. {instead of resizes}
