Semi-spherical container
thomas_kozakthomas_kozak Member Posts: 38 ✭✭
edited June 2016 in Community Support
The goal is to design a container (partial sphere) of given volume which is attached to a plane via a port of a given radius.  Ideally these would be parametric. I believe this can be done via variables but constructing the expression is giving me problems.
The sketch would be a circle split by a chord of constrained length (2*radius of the port).  The radius of the large circle should be definable by the length of the chord and the known area of the resulting circular cap.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,984 image
    Actually the math is quite horrendous as you have to solve a depressed cubic equation. Needs someone far more clever than me!
  • thomas_kozakthomas_kozak Member Posts: 38 ✭✭
    Thanks in any case for the input!  For the time being I'm giving up on formulating it directly since that math is over my head too.  Fortunately I think I can write some javascript to brute-force approximate the radius of the sphere which will be a good patch until I can figure out the right expression.
    Actually you could write it fairly easily in FeatureScript, doing an iteration until the volume is within a certain tolerance.
    That's a nice bit of featurescript, thanks!  Pretty much how I was doing it in JS, but directly in onshape.  I'd still like to be able to get the exact value via an equation but I guess I'll have to hit up some math folks.  This will work for now.
