Copied workspace and all my feature list actions disappeared!
in General
I tried copying my workspace and when I checked my action history, I saw in red "User Code."
My original document still has the history, and I'm only doing this trick to reduce my document size because my storage limit is being reached! Does anyone know what that User Code is? it's some kind of error it looks like?
Thanks
Thanks
1. "User Code" issue in one tab of a complex design I am working on.
2. Linear patterns or mirroring no longer work.
3. Drawings behaving badly like the properties of a view appearing when trying to insert ordinate dimensions or Notes with Leaders.
4. When trying to edit this post, I am having great difficulty positioning the cursor, in that whole adjacent text are selected rather than between text. Maybe my mouse battery is low?
I have raised separate tickets on Items 1 & 2 above. I haven't raised a ticket on Item 3, as I now think it must be related to the most recent release. Hopefully all will be fixed soon.
Finally i tried to copy the part studio into existing document(document created before to the new update),this works fine.No "User code " issue.
We have fixed the issue and are running a process to repair the affected documents. Most of the affected documents have already been repaired, so you should be able to make copies once again.
However, we have not repaired the copies (we are working on a way to do that) so they will still appear with "User Code" in the feature list. If you need data in these copies, please open a support ticket and share the copy with support.
We are very sorry about the inconvenience.
