Add .dxf as a sheet in a drawing after importing?
jackson_king
OS Professional Posts: 80 PRO
Is there a way to add a dxf to an existing drawing? Such as formed model is dimensioned on layout 1 and then dxf added as layout 2 to represent to flat pattern of the part. Like a workaround for how SW let's you add either the flattened part or formed to a drawing.
Also, is there a way to chose the name when exporting to a .dwg or .dxf? Instead of the OS auto-created one?
1
PeteYodis
Moderator, Onshape Employees Posts: 576
@jackson_king Import the flattened DXF into a part studio sketch and create solid geometry. Then on the drawing, reference that solid geometry in a view that you create.5
