Export Face as .dxf
Hi Everyone
I am looking to export the Front Face from the part attached to .dxf for CNC pathing. (Please see attached screenshot)
I only seem to be able to export one face section at a time.
Any help would be appreciated.
Many Thanks
Many Thanks
Twitter: @bradleysauln
Create a new sketch on that face, then select all the edges that you want to export and click the "Use" button. Exit out of the sketch, right-click on the sketch you just created in the feature tree and select export.
That should put just those edges into the dxf/dwg for you.
