Mating screw holes of two parts
shai_perednik
Member Posts: 56 ✭✭
I have a busing and and a housing part, they connect in the physical world with 4 screws through there respective 4 slots. No matter which mate I try, I cannot get the 4 holes to align. Even aligning the shaft hole then rotating on the axis, I still can't get a 90deg rotation to make all the holes align. Am I missing something? Should I be using a different kind of mate?
Thank you!
Thank you!
Optionsethan Member, Onshape Employees Posts: 24After you add your fastened mate. Click the drop down on the mate on the left of your screen. Right click the mate connector of the part that is not fixed, and select edit. Then select move and rotate the part until it is perfect!5
Regards,
OS
