Can a Tetrad shape be created by "sewing" four adjacent sketched triangles into a Body?
paul_sorensenpaul_sorensen Member, Developers Posts: 3
Can a Tetrad shape be created by "sewing" four adjacent sketched triangles forming a closed space into a Body?
Likewise, can a collection of closed faces be made into a Body?
  • daniel_splawskidaniel_splawski Member Posts: 66 ✭✭
    I don't know about sewing four adjacent triangles together, but if you were to extrude one triangle and the use the extrude>intersection feature to remove the excess material I believe it would have the same result.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,847
    No, there is no "sew" function for faces or sketches. You could (as suggested above) extrude a triangle with draft that would give you the same result.
