quit(), exit() or stop()?
billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,115 PRO
edited July 2016 in FeatureScript
Let's say I'm checking a bunch of imported data and I decide to just give up.
<div>&nbsp; &nbsp; &nbsp;println('there\'s no data to read\nplease readData first');
<span style="font-family: Flama, sans-serif;">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; quit();</span></div>
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,248 image
    return;
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    break;
    return; leaves a function and returns you to the calling function, I need all feature script to die.
    break; leaves a loop, I'm not in a loop.
    In php it's called exit; it kills everything.
    I'm using return(true) & return(false) to guard entire blocks of code from executing which works but its really ugly.
    So I'm converting readData.csv into a vector array using a function and if things aren't correct I want to post a note and quit. Using return(false) means I have to handle this every time I call this function which is really ugly.
    Another way to handle this is to give me an onload() function, remember this is like javascript. Do you have this? A way to execute a function onload? Onload() converts readData.csv into vectors. Sweet, then my vector array is ready for all subsequent feature function calls.
  • john_f_carrjohn_f_carr Onshape Employees Posts: 74 image
    How about
        throw regenError('Sorry, that input is too confusing');
    edited July 2016
    I like throw regenError('Sorry, that input is too confusing');
    Script running:
    Script error and I capture event:
    Throw error:
    I like this because the feature goes red indicating an error. Not sure I like all to links to broken code. Maybe there should be a silent mode that doesn't include these links.
    throw error('works');
    Thanks John,
