How do I make a line connecting two different sketches?
stephen_fisher
Member Posts: 1 ✭
I made a drawing that has 12 sketches and i want to make a line connecting the vertices of two different sketches. If someone could answer quickly it would be much appreciated.
MBartlett21
Member, OS Professional, Developers Posts: 2,063 ✭✭✭✭✭
You can just use 3d fit spline in the Onshape toolbar5
Please refer below video,
Another option would be the featurescript 3D spline tool. (Thanks Illya.) Less clicks and no plane to make, which may be good of bad depending on whether you'd want it later.
Cheers, Owen S.
i couldnt find the featurescript you are talking about, could you please post the link? thanks
