Upload Solidworks or IGS files.
diarmuiddiarmuid Member Posts: 2 EDU
I'm having issues uploading Solidworks or iges files. The file will upload but I don’t see any geometry. All the tab shows is the Name, File name and File type. This seems to be the same for any file type,  I have tried .sldprt .sldasm .igs and .x_t file types and all have the same issue. Am I missing something when trying to import or is there an issue with the system?
  • diarmuiddiarmuid Member Posts: 2 EDU
    Ok I figured it out... right click the tab and translate I was having issues with the sldasm file (possibly because of the lack of .sldprt files). However why did the translate not happen automatically when I uploaded the file?
  • 3D3D OS Professional Posts: 52 ✭✭
    Any recommendations on the best way to work with or convert .edrw files?
    From online research seems to be Solidworks file type?
    In searching on the forum & / help, there does not seem to be any relevant information.
    Would appreciate help from anyone who knows.
    Thanks in advance.
    .edrw is an eDrawings viewer file and cannot be opened by anything other than eDrawings.
  • HakroHakro Member Posts: 67 ✭✭✭
    You can download the free eDrawings Viewer from www.edrawingsviewer.com.
    Can open these formats:
