What are you looking forward to in Drawings?
in Drawings
I had a modeling issue and I ended up going to the help file to solve it. While in the help file I noticed it covered the upcoming Drawings. I know Drawings is in closed beta right now, so I am sure it has lots of improvements ahead, but the documentation left me very underwhelmed in its capabilities.
So other than inserting a view and adding a simple dimension, what drawing capabilities do people need or use the most.
Here is my list of top items
1. Being able to use my own template.
2. Full support of GD&T.
3. Ability to add inspection numbers to dimensions including the boarder around the number.
4. Ability to custom symbols in views and in notes.
5. Robust note editing and management.
Lots of things would be nice, but for me these are the capabilities that I need to make it useful.
Regardless of what bells and whistles there are: if I can't sprinkle and manipulate dimensions like pixie dust, I quickly start to feel like an unwilling slave to drudgery. And productivity collapses, particularly on intricate parts.
Too many drawing packages are designed to meet the checklist mentality of the person who signs checks/cheques, and that checklist was developed in consultation with the head of Design. These guys don't have to drive the frigging thing... and generally, it shows!
+1 for fast, relaxed and unambiguous picking up of inference points for adding dimensions.
- @andrew_troup 's "smooth, fast, non-laggy responsiveness, and fast, relaxed and unambiguous picking up of inference points for adding dimensions"
- Smart dimension tool (like we have in sketch mode) which can handle also Iso/Dimetric views.
- Easy integrated template modification / copying
- Same functionality what we are used to have in 3D (full co-operation with follow-me etc.)
- Perfect dwg/dxf handling and dimensioning for imported files.
-Smart dimension tool
-Easy copy and change of drawings for fast creation of reducing repetitive tasks. (ideally also a replace part feature)
-BOMs
-Auto propagation of properties to Template
- User defined template with auto propagation of properties
- Smart dimension tool along with auto dimensioning and arrange tool like autodesk inventor
- GD & T
- Bill of material
1. Fully associative dimensioning in drawing with model:- Typically whenever part is changed drawings get updated. But that flow should also be reverse. Whenever I create any model it should possible to bring required feature dimensions on drawings so that whenever I change any dimension on drawing it will automatically update in model.
2. GD and T
3. Fully parametric BOM
4. Easier template creation with auto propagation of part properties such as material, weight, part name etc.
5. All symbols needed for manufacturing processes such as machining, welding, casting, forging etc. with ability to customize them
6. Easier ECN management
7. Similar real time collaboration, version management as in part/assembly mode
8. Sketch tools in drawings to create customized shapes
9. All ranges of limits and fits
10.Availability of easier methods for creation of notes
Any product built up in Onshape may contain many number of part studios and assembly tabs. Even some of the part studios may contain multi body parts. It makes difficult to search them in whole document. So, the provision as mentioned above in second type would be helpful.
More information about coming openBoM release is here.
https://medium.com/@openbom/onshape-openbom-integrated-app-a-sneak-preview-of-how-it-works-ccab4bd5a7cb
Weld symbols!
This Oleg, co-founder of openBoM. Have you had a chance on what are we doing? There is openBoM connected app we released 1.5 months ago. These days, we're at final stages to deliver "integrated app". Take a look for more details here https://medium.com/@openbom/a-new-way-of-managing-bom-sharing-and-collaboration-in-the-openbom-integrated-app-for-onshape-d79a7e915eae
If you're interested to test it in private beta, please let me know. I will send you an invite.
Thanks,
Oleg [at] openbom [dot] com.
2. fractional dimensions
3. weld symbols
4. broken views
5. exploded views
openBoM integrated app is available on App Store now and it can update part and assembly information (version, state, description, part number) from BOM. The opposite direction works as well - when you change the geometry - add / remove parts, the updates will be automatically done in BOMs.
We don't allow to put BOM in Onshape in drawings, but we are working on this feature. It will come later.
Drawings is halting my productivity and communication with engineers, I have even had to export to other CAD to create the necessary information.
Please spend as much time on this very important part of any CAD software as you do on other areas.
I really like Onshape but drawings really lets it down
- Multiple balloons with the same leader; i.e. detail part, washer, screw
- Multiple leaders with a single balloon; point to multiple instances of the same part/detail
- Draw reference geometry (circles and lines) with snaps to model geometry
- Dimension references to hidden lines and reference geometry (I know, "don't dimension to hidden lines", except when you don't have much of a choice.)
- Edit detail bubble names/letters
- Hide detail bubble circle
- Hide/show parts in assembly drawings (easier creation of subassembly drawings from main assembly)
- Show/hide dimensions from sketches and extrudes/fillets/chamfers
In all, I have been disappointed by drawings in its current state.I second that, specifically I'm looking for the weight to be automatically propagated.
1- Having the possibility to hatch different materials with different hatching symbols.
2- Improving the hatching automatic spacing. Sometimes you get just one line of hatching for a surface. If you cannot get the software to do it right, please give us the possibility to adjust it ourselves.
3- Break view on sections.
4- Local sections on an external view. We have to do it several times in a project. (see provided example)
5- The possibility to break a part in a drawing (not for real) to show what is under it. (see provided example). This could possibly be done with the “local section” tool I mention on point 4-
Léonard de Vinci
