Dialog box not going away
dan_schniersdan_schniers Member Posts: 16 ✭✭
Has anyone had a issue with the dialog box not going away after picking a different command. see attached image.
    @dan_schniers can you submit a ticket?  This is usually a browser/graphics issue.  Seen a few things fix this.  Browser/operating system would be helpful as well.
  • mahirmahir Member, Developers Posts: 1,315 ✭✭✭✭✭
    @dan_schniers, I often get random graphical artifacts - nothing repeatable, though. However, nice thing about working in a browser is you can just hit reload. This is essentially the same thing as closing and opening the document but quicker.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,866
    @dan_schniers - I can tell by the font in your tabs that you are running Windows (?) just make sure you are running Chrome or Firefox and you should be ok.
  • dan_schniersdan_schniers Member Posts: 16 ✭✭
    The Browser seems to be working fine now, I am using Chrome with windows 7 Enterprise.
    Thanks for you immediate help.
  • jochen333jochen333 OS Professional Posts: 28 PRO
    I have this too on on of my computers.
    Windows 10, chrome updated.
    Didnt happen on my other computers, even with the same specs.
  • bert_fouriebert_fourie Member Posts: 101 PRO
    Same here, Windows 10 and Chrome. I did a reboot and that solved the problem.
    edited July 2016
    @dan_schniers, Sometimes it is happening due to browser/graphics issue.
    Work around:-
    Kindly hit F5 button (Refresh) from keyboard and reload the model. Now you can able to move dialogue box if you are not to move then raise a support ticket for this issue. Onshape support team will definitely help you in this case.
