How do I make an Arc COINSIDENT w/2 Lns?
Boswell_INNISSBoswell_INNISS Member Posts: 10
[on Perimeter of cir]
Thanks for your time!
gripWIN@gmail.com
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,909 image
    Tangent constraint
    @Boswell_INNISS, You can use tangent constrain.
    Tangent
    Shortcut: t
    tangent constraint icon in sketch toolbar
    Form a tangent relation between two curves, or between a curve and a plane.
    Constraints can be toggled on while you make selections. Toggle Tangent on and each pair of entities you select are constrained to each other. Click Tangent again to toggle off, or select another tool to toggle off automatically.
    Select two or more curves:
    tangent example selection 1
    Click the Tangent constraint tool:
    tangent example result 1
    tangent example selection 2
    tangent example result 2
    tangent example selection 3
    tangent example result 3
    tangent example selection 4
    tangent example result 4
    circleplanetangentbefore
    circleplanetangentafter
    Steps
    1. In the graphics area, select two or more curves.
    2. Click tangent constraint icon or press the T key.
  • Boswell_INNISSBoswell_INNISS Member Posts: 10
    With 2 Lns, like a corner, ... make C ir Tan?
