Need Example for grenrating Signature API
manokar_munisamymanokar_munisamy Member, Developers Posts: 6
I am developing a plugin in vb.net which is connected to onshape application ,where i need to access some information from your server, so i gone through the API Documentation. since i am new to accessing API there is no examples in your document to get started,first i need an example to access your api to genrating Signature from my plugin developed in vb.net
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015
    @manokar_munisamy We do post all our public examples here for the API but it is still not fully open to the public yet.  https://github.com/onshape-public  Once we launch the API publicly, you will be able to do OAuth and use API keys with your apps.
  • manokar_munisamymanokar_munisamy Member, Developers Posts: 6
    Hi thanks for the information, i used link https://github.com/onshape-public/app-windows-sample to download and run and it asked for a login, after entering login details the page is redirected and shows HTTP 404 error , but it has been loged in i
    @manokar_munisamy when running apps locally that use OAuth you will need to setup your redirect to go to your machine.
    Yaa got that now i got Authcode but after that on requesting tocken it response 401 error unauthorized , where do we get authorized
  • james_mann066james_mann066 Member Posts: 2
    Did you ever resolve this issue? I'm stuck on the same issue! I got the Authcode back fine, but then I get a 401 in response to my form post.
