Part studio is great for top down designing, but there must be a way to get the old sw assemblies in there as assemblies.
Surely, as one tab in os knows where the parts should be, a transform routine could be invoked to move the part studio bits to the same position? Even as a once only option.
Transform adjusts a part's location and orientation in 3D space with the option to copy the part in place.
- Make changes to one part and use both to create different bodies during a later operation.
- Make a copy of a part prior to a series of operations enabling you to reference the original state for ancillary operations.
- Create multiple copies of a part in order to create multiple variants.
If you need to create multiple copies of a part at once, use the Pattern feature with a distance of 0 (zero).
Before transform by mate connectors
After transform by mate connectors
Before rotate
After rotate
Before copy in place
After copy in place
Before scale uniformly
After scale uniformly
Kindly refer below video for more detail about transform by mate connector
The automatic processing happens only for files that Onshape can translate. All other files are simply imported into a tab.
Note:- Check first box only (Second box must be uncheck) if you wanted all assembly part in one part studio.The annoying thing is that the parts are perfectly assembled in the OS assembly, but effectively locked in a glass case, unable to be directly worked on. So, as all the data required to move the part studio parts to the same positions as in the assembly actually exists in the onshape file, why isn't there a "Replicate Assembly Part Positions" command in part studio.
I would guess that most people paying their Onshape subscription now, and a long way into the future, will have legacy assemblies they want to import. And I suspect Onshape's import system is the only CAD system that destroys assemblies during import. Clearly the RAPP command should be a top priority.
