Labelled dimensions in sketch referencing a table
bert_fourie
Member Posts: 101 PRO
I would like to generate a family of parts. Is it possible to to label certain dimensions A, B and C etc and reference them to a label in a table, so I can select one specific line in that table to generate a detailed drawing with its corresponding values for A, B and C?
Optionsbert_fourie Member Posts: 101 PROYes, thank you Owen, that is what I am after, just did not know how to say it5
Cody demonstrated something similar in a webinar on a pattern feature using arrays. The first array had list of options, the subsequent arrays gave a value based on what was selected from the first one. I think that would yield what is required here, providing I'm even thinking in the right direction.
Regards,
Owen S
But like @owen_sparks remembered, there is a way to set multiple variables by changing one. Similar to choosing a line from an array. But it is only possible by editing that 'config' variable, ie. not possible from assembly or drawings.
https://cad.onshape.com/help/#variable.htm?Highlight=variables --> Using arrays in variables
Onshape is perfectly aware of the need for configurations and some forum messages have leaked that it shouldn't be too far away and that we are allowed to expect something awesome (as usual
