Defeaturing a complicated model
Hi,
I would like to defeature an assembly for FEM analysis - like remove small faces, some small details like holes etc. Could this be done with Onshape? This feature is available in Solidworks but was not able to find on Onshape. Any ideas or feedback would be helpful.
Thanks
Thanks
Sometime and I even do export and then re-import tho clean up the tree when working on part's/assemblies as it doesn't take long to get a couple hundred features.
When doing this it would be handy to have a tool like in SW to scan for edges under a specified length to find all the small faces, could something like this be made with FS?
It should not be hard to write an FS feature that can find small edges / faces and call opDeleteFace on them (ignoring failures).
Yes I think it would be near impossible to create a de feature tool get rid of all the small geometry and I was not expecting to be able to do this in FS I'm just after a way to find the small faces then manually deal with the once found which is more a tool like measure tool than a feature.
