Multiple drawing sheet issues
In drawings when having multiple sheets, the drawing number and revision number typed into sheet 1 is not auto generated into the following sheets. This will not change, so it should be auto generated. Page numbering seems to work fine.
It would also be great if one could copy section views, detail views etc into different pages.
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,436
    if you right click a view and select properties you can set which sheet it should be on.
    jarrett_brewerjarrett_brewer Member Posts: 1
    I second Jarand's comment.  I don't think you understood what he was saying.
