Drawing with demons ions for machinist.
Hey all,
I've created a part I will need turned out of aluminum. Seeing how I don't have a lathe in my shop I will have to take my plans to a machine shop. Is there currently any way to export a drawing that has the measurements of everything including the lengths of extrusions. I've seen them before with other cad programs that show several views of the part with measurements of everything. I hope I've explained my question clearly.
Thanks alot
Thanks alot
To create a drawing of your part, right-click on the part and select "Create drawing of ....", then select a drawing sheet format in the dialog and select the "4-Views" option. This will add a new tab to your document with the drawing in it.
You will then need to add all the dimensions that are required by using the dimension tools.
When you are finished, you can then print or export the drawing as a PDF (or dwg/dxf).
