Work around for Escape Key exits full screen.
Phil_AngileriPhil_Angileri Member Posts: 3 PRO
I am a habitual ESC key pusher so this has been driving me crazy for a while.
If you have a Space Mouse Pro you can Re Map the ESC button to be CTRL ESC instead.  This will keep you in full screen but still cancel commands.
    I suppose this is browser specific problem.. I'm using chrome and it doesn't mind me hitting esc in fullscreen, F11 triggers fullscreen on/off.
    Chrome does not use Apple's API for fullscreen mode, that's why it does not use escape for exit full screen. It causes other issues elsewhere, but I cannot recall what they are. Not with OS as I recall. I still prefer to use Safari over the privacy stealing, resource hog that is Chrome for Mac. ;-)
    I'm running w10..
    I suppose we should include more infomation in posts that are meant for certain segment..
